connection advice
Discussion in 'AV Receivers & Amplifiers' started by garye, Sep 3, 2001.
  1. garye
    garye
    how can i connect my tv to my sony str-de445 amp if the tv has no audio outs? <img src="confused.gif" border="0">
  2. RobDickinson
    RobDickinson
    Mar 8, 2001
    4,756
    Christchurch , New Zealand
    +748
    If it has a (free)scart socket you can get a scart-&gt; stereo phono cable and this should sort you out (you may need to play with the TV's setup to change it to output via the scart socket used).
