connection advice
Discussion in 'AV Receivers & Amplifiers' started by garye, Sep 27, 2001.
  1. garye
    garye
    can someone please advise on easiest way to connect following:<br />str-de445 receiver<br />digibox<br />tv two scarts no audio outs<br />wharfedale m5 dvd player<br />sony slv-av100 video<br /> <img src="confused.gif" border="0">
  2. Jase
    Jase
    Mar 16, 2001
    9,407
    South Coast
    +856
    Here goes:
    Dvd to TV - Scart 1
    Video to TV - Scart 2
    Digibox to Video (2nd scart on video i.e video pass thru)
    Audio<br />Dvd to reciever via Digital cable (Optical or Coaxial)
    Digibox to receiver
    Video to receiver
    hope this helps
    cheers
  3. Doubledoom
    Doubledoom
    I would change that slightly.
    DVD &gt; TV (into s-video scart)<br />Sky &gt; TV (RGB scart)<br />Sky &gt; VCR (scart)
    There is no need for the video to be connected up directly to the tv. I assume the DVD is going to be used less than the digibox, hence why i favoured the digibox on the RGB scart.
    Alternatively, if the video player isn't a priority:
    DVD &gt; Digibox (into vcr scart)<br />Digibox &gt; TV (into RGB scart)<br />Video &gt; TV (scart 2)<br />aerial &gt; sky&gt;video&gt;tv
    The above gives RGB on both sky and the dvd but means you have to record via the RF aerial lead, like the old days.
