connection advice - x-box and davs 550
Discussion in 'Nintendo Forums' started by PaulBrum, Dec 23, 2003.
  1. PaulBrum
    PaulBrum
    Apr 15, 2003
    138
    Solihull
    Chaps - looking for some advice on how best to connect my x-box to get 5.1 sound.
    Got a sony TV (FQ70), sky plus and davs 550 system.
    - sky plus connected to TV via THOR scart
    - Davs 550 connected to TV via S-Video to scart lead
    - Sky plus connected to Davs 550 via optical link (gives digital 5.1 sound) - therfore, I don't use the sound on the TV
    Problem:
    I have a spare RGB scart on my TV, so could get a scart lead to connect X-Box to TV - BUT - this won't give me surround sound thru the DAVS system
    Any bright ideas ?????
    Paulxx
  2. Big Jim
    Big Jim
  3. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    Yeah, you need the Advanced Scart with optical out, and an optical cable to go from that to the receiver. Your receiver has a spare optical in, right?
  4. bobble
    bobble
    Jul 8, 2002
    159
    2
    +6
  5. PaulBrum
    PaulBrum
    Apr 15, 2003
    138
    Solihull
    thanks chaps - so - i need:
    advanced scart cable (xbox) - this has a toslink connector as well ??
    xbox scart to rgb 2 on my tv, and optical link to the davs unit (via switch)
    why is life never easy !!!!!
  6. inzaman
    inzaman
    Dec 16, 2002
    7,964
    Derby
    +1,029
    Paulbrum, that is correct i am sure that you will have to get a toslink cable as well.
    It isnt straight forward but it will be worth it once you get it hooked up
  7. nealgs
    nealgs
    If you get the original MS Advanced Scart cable then you will also need to get a optical toslink cable to (not included with MS one)
    If you get the one from Game, this comes with the optical toslink cable - it's also £5 cheaper, but as they say, you get what you pay for
    So not sure if quality suffers with cheaper price
    Gary
