connection advice req.
Discussion in 'Projectors, Screens & Video Processors' started by Taz, Jun 21, 2003.
  1. Taz
    Taz
    Hi guys, Im getting myself a PJ again (AE100) and need some advice on what leads to buy to connect it to my system please...
    I have a Denon 3803, DVD with component out, Xbox (via RGB to TV scart) FTA (RGB) and 2 Game cubes via switch box s video and DVDR (RGB to TV) all my RGB connex to TV via a switch box
    Just wondered what leads im gonna need to connect it all to PJ and the best way of doing things.
  2. Kramer
    Kramer
    The AE100 doesn't accept "scart" RGB :(
    Best/easiest option IMO is to run everything through the 3803 & then just 1 component connection to the PJ.
    The 3803 will "upscale" all inputs to component. it doesn't perform any magic though, just facilitates a single cable run to display device.
    Other options are a ProV for s-video to VGA conversion (probably better for games consoles etc...) or a HCPC to extract the last drop of performance from the AE100.
    Best of luck with it Taz ;)
  3. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    High Wycombe, Bucks, UK
    +59
    Since it looks like I will be in on this regardless I'd better have my say. :D
    There are options for component with all the consoles, which is good. As there is with the DVD. The only stumbling block to me is the DVB-T box.
    Only easy option at the moment is to add an RGB to S-video convetor in the output stage and this can feed s-video to the 3803 for conversion.
    Xbox = component = 3803
    GC = component = 3803
    DVD = component = 3803
    DVB-T = s-video = 3803
    3803 = component = pj
    PC = VGA lead = pj
    And if the DVDR is needed (which I suspect it will) then the RGB=s-video convertor can go after that in the chain.
