connection advice needed for newbie
Discussion in 'Plasma TVs Forum' started by sloxam, Jun 6, 2005.
  1. sloxam
    sloxam
    Jun 1, 2005
    38
    hi, which would be the best way to connect these items as single connections don't seem to give the best pq. i have IXOS scarts and RGB only on the sky connection.
    37PF9946 screen.
    HTS3500S home cinema/DVD
    sky box.
    i thought about sky to DVD to either s-video or VGA as i've read that s-video and/or VGA can help solve PQ probs. not sure whether VGA will display normal pictures on this screen though. no composite inputs on tv only outputs from DVD.
    sorry if i seem thick but i am new to this game and just want the best picture possible before i go to ISF.
  2. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    Really, I wouldn't bother with ISF on that, bit like putting 18" alloys on a 1.6 escort. You need to get your sources sorted out 1st as a minimum. The best you can do with sky is RGB scart, and you are stuck with s-video for the DVD. It's not up to the job.
