macshimi
I can usually find what I want by search the forum, but this has me stumped.
My kit list is made up of a Panasonic TH-42PX70B TV, a Panasonic SC-BTT362 Home Theatre and a newly acquired Humax DTR-T1000 500GB YouView DTR.
I need help in getting the sound from YouView to play through the BTT362. I tried connecting the YouView and BT362 directly using a HDMI cable, it would work only after repeatingswitching the YouView on and off.
I phoned Panasonic and they said you should never connect the YouView in this way, it must go directly to the TV.
If I do that, I cant get the sound through the BT362 speakers. Panasonic said to use the Optical Out on the TV, my model doesnt have this feature.
All help will be gratefully received.
PS I hope I have posted this in the right section, Im sure someone will tell if I havent!
