I currently have an xbox and sky+ box connected to a Samsung D8000 TV with HDMI cables.
I now want to set up a Samsung HD-450 soundbar. I see 2 options:
1) Connect xbox and sky+ with 2 separate Optical audio cables to the sound bar which has 2 optical input ports.
2) Leave the xbox/sky+ as they are, and connect the soundbar to the TV optical out port with a single optical cable.
I think either would work - but is there likely to be any less of audio quality with option 2, where the sound is going via the TV rather than going directly from xbox/sky+ to the sound bar?
Thanks!
Thanks!
