Connecting xbox 360 through a dvi-i port.
Discussion in 'LCD & LED LCD TVs Forum' started by chrispurvis100, Feb 12, 2009.
Tags:
  1. chrispurvis100
    chrispurvis100
    Feb 11, 2009
    19
    Hi everyone. I have a phillips 32 inch lcd (2.5 years old)which is hd ready, but only has a dvi-i port. Not sure of make at the moment, but will have a look when I get home.
    Basically, I have purchased a vga lead for the xbox and then a vga-dvi adaptor. With everything connected, when I switch the xbox on and go to the hd channel on the tv, all I get is a message saying 'no input signal'. When I tried a hdmi-dvi lead, I had a message saying 'video source not recognized.
    I cannot find any settings to change in the on screen menu for hd. Does anyone have an idea on how I can get my xbox to work on this tv? Or am I going to have to bite the bullet and buy a new tv? (42 inch Plasma's are looking good value at the moment! :D )
  2. chrispurvis100
    chrispurvis100
    Feb 11, 2009
    19
    Do I need the select 'PC' rather than 'HD'?
  3. mclrn227
    mclrn227
    now that you changed to an HD tv, did you also change the little switch on the xbox av cable to hd aswell?
  4. chrispurvis100
    chrispurvis100
    Feb 11, 2009
    19
    There is no such switch on the vga cable. I cannot use the standard lead that comes with the xbox as I have to connect to DVI. :thumbsup:
