Connecting X-box to AV
Discussion in 'Cables & Switches' started by FreiKorps, Dec 27, 2003.
  1. FreiKorps
    FreiKorps
    Dec 27, 2003
    Scotland
    Hi im realy new to home cinema so i dont know all the ins and outs.Im realy confused about connecting my x-box to my s-master
    AV 5.1ch Digital Amplifier.Iv heard about the Xbox Advanced AV Pack but dont know if i need it , i can plug the 3 cables (video in,l-audio,r-Audio) in to the back of the av.Can i get better quality with it? My AV has also got just an optical in slot (heard that you need optical in and out).Hope this makes sense :rolleyes:
  2. Kramer
    Kramer
    You need the advanced kit (optical out) to benefit from the xbox's Dolby Digital 5.1 output.
    Comet do one (Gamestar IIRC) for £9.99 which includes a pretty decent optical cale. It also supports RGB so you'll get far better pictures on your TV.
    BTW, welcome to the forums :)
  3. lmccauley
    lmccauley
    Oct 24, 2000
    3,444
    Newcastle
    +278
    As Kramer says, buy an Advanced AV SCART kit (either the Gamestar one, or the Joytech one, which is £15 - don't bother with the Official MS one as it's £20 and doesn't include the optical lead). Your AV amp is fine with just an optical input. Simply plug the Advanced AV kit into the xbox, plug the optical lead into that and your AV amp, and the SCART end into an RGB SCART socket on your TV.
    Cheers,
    Liam
  4. FreiKorps
    FreiKorps
    Dec 27, 2003
    Scotland
    You'v made it hell of a lot easier.I'll go get the advanced kit to tomorrow cause im goin to town.Thanks guys.
    :D
  5. FreiKorps
    FreiKorps
    Dec 27, 2003
    Scotland
    Just relised will the optical out kit work with and optical In on the av ?
  6. lmccauley
    lmccauley
    Oct 24, 2000
    3,444
    Newcastle
    +278
    Yes.
    That's exactly how mine is connected up.
    Cheers,
    Liam
  7. fuzzybee
    fuzzybee
    Apr 27, 2002
    1,498
    Chesterfield town of the crooked (Spire)
    +72
    The Joytech one certainly is good value as it includes both RGB scart and s-video connections on the same cable aswell as the optical cable. However having recently tested both i can say the official advanced RGB scart cable certainly gives the better picture(or it does on my 42inch plasma)
    Don't worry about optical cables as they are the same connection either way(input-output) also remember to enable Dolby Digital/DTS in the xbox dashboard :smashin:
