kdw133
I'm attempting to connect a Vizio SB4051 soundbar to a Samsung UN60F8000 TV. The manual says the HDMI ARC will be the best connection quality. When I set it up, the TV will recognize the soundbar to some degree (the TV remote will control the soundbar volume and it says the soundbar model number right on screen), but it won't play any sound. I have the speakers set to Receiver as both manuals say.
I contacted Samsung support and they said because the soundbar does not have Anynet+ it won't work. I find that odd because the TV can obviously see, recognize, and control the soundbar. Beyond that, you would think two devices with HDMI ARC would work together.
Any thoughts? Is this just the way it is or is there something else I can try. Is it even worth it to worry about the HDMI connection or will the coax quality be "good enough?"
