Connecting video thru Yamaha RXV2500
Discussion in 'AV Receivers & Amplifiers' started by stevegreen, Nov 7, 2005.
Tags:
  1. stevegreen
    stevegreen
    May 14, 2001
    8,745
    in my Hymer
    +921
    I will be starting the wiring for my HC room soon and could do with peoples experiences on routing video through their AV amp.
    I intend to send just one component cable from the amp to the PJ, routing the DVD picture through the amp and also an Xbox
    Is this method likely to make much difference to the picture quality in comparison to connecting the DVD player directly to the PJ?
  2. mista
    mista
    Oct 12, 2004
    506
    Cambridge
    +17
    Hi There,
    I have one of these and my xbox, DVD and TV is all routed through my 2500 - There is absoultly no difference in quality.
    Mista
  3. stevegreen
    stevegreen
    May 14, 2001
    8,745
    in my Hymer
    +921
    Just what I wanted to hear. What are you connecting your 2500 to out of interest, and is it through component?
  4. skinnyfat
    skinnyfat
    I can second that :thumbsup:
  5. Drew2
    Drew2
    Jan 12, 2005
    699
    Tsukuba, Japan
    +32
    Just bought one yesterday for an absolute bargain price of 325 quid.
    Glad to hear that you notice no difference when connecting your units through it. Was considering plugging my PS2 and Momitsu in - will now try it out!
  6. karlak
    karlak
    Sep 4, 2005
    2,944
    +2,573
    2nd hand I guess ?
  7. Drew2
    Drew2
    Jan 12, 2005
    699
    Tsukuba, Japan
    +32
    Ex-display, actually it was still on display! Happy chappy :thumbsup:
  8. John
    John
    Dec 13, 2002
    11,724
    +3,426
    I have my set up wired similarly , all through my 757 .
    The only drawback I find , is that the picture settings are a compromise between all the sources . Admitedly , I have Sky, DVD and Xbox .
    Depending on your DVD player , it may have its own onboard picture adjustments .
    Of course , if your display does not allow separate settings for separate inputs , it irrelevant .
    I've wondered how Gordon and Piers have gone on with such a set up , they must have done one . Which method they get the best results from , and how they compare.
    John
  9. Drew2
    Drew2
    Jan 12, 2005
    699
    Tsukuba, Japan
    +32
    I have just hooked up my Momitsu by component running 1080i.
    The picture quality certainly looks as good as ever, however I have noticed that the motion is "staggered". This might be down to the fact that it was a PAL disc I was watching and the amp is only set up for NTSC signals and that the Momitsu is sending out a PAL - NTSC signal even though I set it to 50Hz. Will spend time tomorrow with different discs and also hook up the PS2 and see how it looks - can't wait to hear the ProLogic II soundtracks..... :smashin:
  10. mista
    mista
    Oct 12, 2004
    506
    Cambridge
    +17
    viewing my picture with a 42 PW7 - TV is going through a js RGB to component convertor - Denon 2910 through componet - and xbox all through component (hidef kit) - I did some testing with the dvd player playing directly through the TV to see if I could see a difference but did not spot any change
    - I can concur that my tv is calibrated to the DVD using the video essentials DVD and your TV is dumb to the fact that you are changing inputs. I personally do not mess with the colour at all on the TV - Change the setting on the xbox is all I find I have to do
    Mista
