I wondered if someone might be able to assist?
I have a Toshiba 27WL54G TV with a Virgin V+ box connected to it via HDMI, and also a PC connected to the TV via the VGA port on the TV.
I currently use the PC to play DVD's+DivX's on the TV, but playback of the DVD's is sometimes a bit jumpy and the drive is a bit noisy. So I was thinking of getting an upscaling DVD player (and in particular, the Samsung DVD-HD 870, as it got great reviews from What-HiFi).
The upscaling DVD obviously needs to be connected to the TV via HDMI, however the TV only has 1 HDMI socket. So my question really is, What is the best way to connect my system together?
Should I ...
Your assistance is greatly appreciated!
Thanks,
Matt
Should I ...
- Get an HDMI switch to allow me to connect both V+ box and DVD Player's HDMI ports to the 1 port on the TV? And if so, are the Auto switches any good? (ie.
- Or, get a different upscaling DVD Player that allows for the V+ box to be connected into the DVD player via HDMI, and then connects to the TV using the 1 HDMI port on the TV. Is this possible? And can you recommend any dvd players that support this? Also, if this IS the case, is it possible (and i think not, but just in case!) to connect the PC into the upscaling DVD player (via VGA/USB/LAN/Some Kind of Magic?) as well as the V+ box, so that it would upscale DivX's without me needing to burn them onto CD first?
- Or, are there any other solutions?!
Thanks,
Matt
