I have a Sony DAVSR4W theatre sytem with a Sony DVD recorder and a KDL3000X TV and want to know how best to connect it all together.
At present the TV ariel goes via the DVD recorder which is then connected to the TV with a HDMI cable and an ariel cable. I have the audio output from the DVD recorder going into the back of the theatre system amp (which is also a DVD player) to the "audio in" connections using two Video Component cables. It all works except on some DVD's I seem to be getting a small lag between when someones mouth opens and the sound from the theatre system, when I use the DVD recorder to play DVD's.
Is this connected properly? Also, how can I connect the theatre system up so that it is used for normal TV?
