connecting up the aspect ratio controller
itsonlyaname
Just to check before I spend hours ripping all my cable out.
I have a PW7 to Js Tech RGB to Quintro Scart Box then to SKY, DVD, PS2 etc.
Will I be able to put the aspect controller in between the Js Tech box and the scart controller or after the Js box hence being able to control the aspect ratio's on everything going through the scart controller.
Any help will be much appreciated.
stevelup
Yes, if you put it between the Quintro and JS converter, it will do the trick for all the inputs into your Quintro.
Steve
