Connecting up a Z4
Discussion in 'Projectors, Screens & Video Processors' started by alpit, Oct 10, 2005.
  1. alpit
    alpit
    Dec 30, 2001
    12
    I currently have a Z2 connected to my HTPC by a DVI-I cable. When I buy a Z4 will I be able connect it to my HTPC using this cable/adapter?
    http://www.lindy.com/uk/productfolder/04/41227/index.php
    Will my DVI-I cable fit in to this? as it's DVI-D connection?
    Will I still be able to use my HTPC as I do now for watching DVD's from my hard drives, Sky (using d-scaler) and for normal pc usage?
  2. n0s
    n0s
    Jun 11, 2005
    173
    16
    Istanbul
    just get a dvi to hdmi adapter, dvi-d is digital, dvi-i is both analoge and digital, thats it, so DVI-I cable is fine.
  3. Comer
    Comer
    Sep 21, 2001
    1,384
    Ireland
    +85
    That is exactly what I use, it works perfectly
