Connecting up a PW7
Discussion in 'Plasma TVs' started by Bobby_Dazzler, Jan 26, 2005.
  1. Bobby_Dazzler
    Bobby_Dazzler
    Hi all
    Can any one help me here.
    I have sky plus and have decided to purchase a PW7 and a Denon 500SD the question is will I be able to run a scart from the sky + to the denon and then run component from the denon to the pw7 ?
    the other question is on the aspect switching.
    I have always connected things via scart so component is something new for me. Will the picture be full screen on the PW7 when I turn all the kit on or will I have to change it each time?
    Regards
    Bobby
  2. tamthetim
    tamthetim
    Nov 7, 2004
    478
    Perth
    +6
    check this link
    http://www.avland.co.uk/denon/dht500sd/rearlrg.jpg
    looks like the scart is output only.....as it says tv.................so think thats no good.
    sky to vga via JSB converter or buy a scart board for the PW7 might be better options for sky+.
    then just have the dvd for the component.................or may want to re-think your choice of all in one system
    maybe someone else could advise?
    cheers, tam
