Connecting up a dvd optically
Discussion in 'Cables & Switches' started by gerdy252, Nov 26, 2001.
  1. gerdy252
    gerdy252
    Needs some advice re : conecting dvd/av amp/tv ;
    Currently TVscart to 6 phono plugs into AV Amp.
    What are my options for linking the DVD to this setup.
    TV has a spare scart, satellite box has a spare scart, but
    AV amp has optical / coaxial + others. Can the AV Amp
    pass the visual image to the tv or does it only handle sound ?
    dvd - pioneer dv340
    AVamp - kenwood 3050
    gerd...
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    The optical connection will only carry sound/bitstreams, no video.
    Use the digital connection (coax or optical) if the AV amplifier should do the decoding from DVD instead the player itself, given of course that the amp can handle DD/DTS.
  3. Doubledoom
    Doubledoom
    Generic answer below - adapt it accordingly
    Various ways to connect depending on what you think is acceptable.
    option 1 - RGB for both DVD and digibox but need to record via the RF.
    Audio carried from TV to Amp and DVD to amp (TV passes audio from vcr and
    digibox)
    DVD > Digibox VCR scart ( use scart lead, set DVD to output RGB)
    Digibox > TV (use scart lead into RGB scart socket)
    Video > TV (scart lead into composite scart socket - Don't use an expensive cable, it would be wasted)
    Aerial > digibox > vcr > TV
    DVD > Amp (using digital co-ax or optical -identical quality, depends on your available connections)
    TV > Amp (using 2x phono connection)
    Option 2 - RGB for digibox and s-video for DVD. Allows recording via the scart. Audio the same as above
    DVD > TV (scart into s-video scart)
    Digibox > TV (scart into RGB scart)
    Digibox > VCR (composite scart - Don't use expensive cable for this one)
    Option 3 - TV doesn't pass audio or doesn't pass it with decent quality. Will require manual switching between sources. Use video connections as option 1 or 2.
    VCR > Amp (using 2x phono connection)
    Digibox > Amp (using 2x phono connection)
