Connecting two DVI devices to one DVI display
Discussion in 'Cables & Switches' started by HitmanIP7, Jan 13, 2005.
  1. HitmanIP7
    HitmanIP7
    Jul 16, 2003
    689
    UK
    +20
    Ive just got a 20.1" widescreen TFT for my PC, which Im going to use for watching DVD's on. At the moment its connected via DVI to my PC. But I cant really make my current PC silent, so I plan to make a silent HTPC for DVD and video playback.
    So what Im trying to find is a switcher which I can connect both PC's to, and output them to the TFT.
    I did a search on the forums, and found the threads about this. But nearly all of them suggested products in the US. I did find one from tmfsolutions.co.uk, but its like £199 :eek:
    Isn't there anything simple and cheap which would do this?
    But obviously not degrading visual quality when Im using either PC.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    for those too lazy to swap the cables round £199 is a worthy investment...............
  3. HitmanIP7
    HitmanIP7
    Jul 16, 2003
    689
    UK
    +20
    lol, I am too lazy :D
  4. cwick
    cwick
    Feb 4, 2002
    2,207
    Reading
    +95
  5. pragmatic
    pragmatic
    Nov 9, 2004
    12,120
    +1,678
    Does the Monitor have a DVI and VGA because if it does then use a converter to connect it DVI-VGA, or from one PC just get a VGA lead. I'm not sure if there is much difference between the two to be honest, espectialy over short runs.
    Also not sure if yours does but some TFT's have a PIP function.
  6. HitmanIP7
    HitmanIP7
    Jul 16, 2003
    689
    UK
    +20
    It does have both VGA and DVI, but my personal oppinion is that you can tell the difference between them. DVI is so much clearer and crisper.
    I saw that Blenkin one, but on another site it said it had been discontinued due to a problem with them.
    I found a few on eBay. They are all from sellers based in the US, and they all look good quality. SO I may possibly go for one of those.
