Connecting TV with coaxial cable to HDMI or RCA
Discussion in 'Digital TV & Video Players & Recorders' started by driver06, Dec 9, 2017.
  1. driver06
    driver06
    Dec 8, 2017
    Monaco
    Hello,
    I have a DVD player with HDMI and RCA outputs that I want to run two built in TVs. One TV can only be fed by RCA and the other only coaxial as a result of the cables being built into a wall. The following u tube posting seems to show how this can be done.
    connecting tv coaxial to dvd player - Yahoo Video Search results
    Firstly, if the above is correct, is it better to use "piggyback" connectors to divide the RCA signal and then convert one for the coaxial cable, or will it be necessary to run one television from the HDMI output, converted to RCA and then to coaxial and the other from RCA directly?
    Finally, is it possible please, to identify the actual products required as there is (to me) a bewildering selection of similar looking equipment. I am an old git who only recently threw away his Betamax player!
  2. JayCee
    JayCee
    Jan 20, 2004
    23,886
    Lanarkshire
    +2,589
    How many RCA Phono outputs does your DVD player have?
    2 (Red/White) as in left/right audio output?
    or
    3 (Yellow/Red/White) as in Composite video & audio?
    or
    5 (Red/Green/Blue/Red/White) as in Component video/audio.
  3. driver06
    driver06
    Dec 8, 2017
    Monaco
    Hello,
    I have number 3 (Yellow/Red/White) as in Composite video & audio.
    Thanks,
    John.
  4. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,600
    Oxford
    +1,335
    Does the TV with coaxial input have an analogue or digital Tuner or both? What make and model is it? Only digital will receive Freeview channels.
  5. driver06
    driver06
    Dec 8, 2017
    Monaco
    I will get the model in the next few days. It is digital. Its only use will be to play DVDs.
  6. driver06
    driver06
    Dec 8, 2017
    Monaco
  7. JayCee
    JayCee
    Jan 20, 2004
    23,886
    Lanarkshire
    +2,589
    You can try it.
  8. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,600
    Oxford
    +1,335
