Connecting TV to DVD and VHS Video recorder
V
vegnomeat
It's pretty obvious I am very new to this home entertainment field. After researcing for a month or so I have ordered a Toshiba 50WT29B rear projection TV along with a Toshiba DVD player and Toshiba VCR, all bundled from Comet for £2000.
Now the hard part, What is the best way to connect them all together for best sound and best picture, I will be using external front speakers.
I am confused by RGB, S-VHS, composite, digital optical etc. I always thouhgt S-VHS was the small round 7 (?) pin connection but I do know what a scart is.
The DVD has one scart, composite and S-VHS (I think).
Thanks in anticipation
Wayne
V
vegnomeat
OK, comet couldn't supply the 50wt29 as it was part of a package and the DVD player wasn't in stock, so they cancelled my order.
Today ordered from empire direct the Toshiba 42wt29b, the toshiba SD 220e DVD and also a Toshiba VCR.
Seeing as the above post generated 0 replies I am trying again.
However, I think I have now gathered more information, a simple yes or no to the following question will suffice :D
The best method of hooking up the DVD to the TV is by Component cable for the picture and by optical cable for the Audio. Am I correct ?
Wayne
-Jay-
yes:D
mansell
indeed
make it so !
