Connecting to the Pannasonic AE500
Discussion in 'Cables & Switches' started by andy9, Jul 24, 2004.
  1. andy9
    andy9
    My DVD player only has a s-video out and a composite video out, obviously the s-video is the best option.
    so i take it all i need is s-video cable to connect up the projector and the player? i will not gain anything by using the s-video to scart connector i have a present will i?
    also can anyone help on these:
    800x600 (SVGA) - will this be the max resolution i can only get using s-video?
    1,024x768 (XGA) - what is XGA?
    1,280x1,024 (SXGA) - what is SXGA??
    thanks.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    S-video 4 pin mini DIN to 4 pin Mini Din is what you need!
    Save scart for RGB enabled device like freeview or sky box.
  3. andy9
    andy9
    thanks, by using s-vdeo does the resolution max out at 800x600?
    ie will i get the projectors full potential with s-video cable?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    ermsort of you will be getting 576i or 480i Video resw as opposed to PC RES without an uprade to PS DVD player you wont gain much, but if DVD is Composite and S-video only I am guessing it is a budget model which may not get the best out of the PJ
  5. andy9
    andy9
    its the sony dav-s800, cost £800 about 20months back, so it was high spec then, maybe not now, may upgrade to a RGB compnent dvd player, only if the picture difference is hugely different! im sceptical of super duper cables and connections sometimes!
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    Very odd that it has no component out!
    £800 for a complete system is budget myfriend! Hi end is £1000+ on a DVD player. £2000+ on AV amp and £5000+ on speakers. Many would argue that with me! £40,000 is the cost of a basic proper HC room conversion!
  7. andy9
    andy9
    oh well, want to lend me a few bob then???
    £800 on a system is pretty good going in a working mans world ;)
  8. andy9
    andy9
    ok for component connections now, went to richers and bought a marantz dv4300, not bad for £117 :)
