connecting to the net via a sky SC201
keyi
is it possible to connect using the SC201 wireless box or is the box solely for use with a skyHD box
cheers peeps keyi
im not clued up with all this techno stuff:(
sykotik
the ps3 is wireless , :smashin:
you dont need to connect it to the "SC201 wireless box" which all intents and purposes is just wireless box for the sky box and "on demand"
keyi
sorry sykotik i should have explained
the ps3 keeps dropping the wifi signal and i have a spare sc201 box and was wondering if it could be used? or is there a way of making the ps3 receive the wifi signal eg by a switch inside
sykotik
aye c :smashin:
i couldn't really say ,if it would work or not ,
i'm guessing no , as there are both wifi receivers/senders
and if the ps3 is dropping signal then i think any thing connected to it will do the same ,
but you can try it , (try both wired and wireless settings when testing it)
how far away is the ps3 from the router ?
have you thought about "home plugs" , you can get some for £30 and there do work i have some homeplug | eBay :smashin:
keyi
just thought id ask before i tried, i dont want to break anything
the router is in the next room but with the stairs in the way
ye ive thought about home plugs but thought id try what ive got first, shame it wont work it would save me £30
sykotik
give it a try , you may have to try the "wired settings" as the Ethernet cable will be connected in the back of the playstation , then into the sky wireless box
could you run a ethernet cable thro the wall and stairs to the router?
keyi
ye mate i can run it through the wall or i can when i can be arsed to do it lol just thought id try something else first as i have it knocking about in the house doing nowt
if i connect via a wire do i have to change some settings? doesnt it just know what im doing?
cheers for the replys
sykotik
no idea mate
it will be a trial and error
iv never use the "sky box" if there will be any settings to change
as for the ps3
go to network setting >"internet connection settings"> custom > then chose wired connection
you could try both ways (wired or wireless) .....really not sure if it would work or not ,
keyi
cheers mate im wondering if thats why my wireless connection isnt working right? (it keeps knocking off)
sykotik
wireless connection can be pain in the ass some time's
do you have other devices connected by wireless , phones can cause connection to drop
is there an other sky wireless box ( you said you had one laid around do you use an other one for your sky tv box)
wired connection will always be best , running an ethernet cable or home plugs are the easiest option ,
do you keep your router on all the time "broadband " can be turned off "fiber needs to on all the time " could do with rest
having loads of devices can disrupt the signal , IE the kidz up stairs, the miss's on the tablet "checking face"*****"book ha ha
keyi
ye mate we have 2 laptops 1 ipad 3 phones and a 2 sky boxes one is wired though the other is connected via a sc201 bow but only pics up a signal for 30 mins gggrrrrr
