connecting to Sony DAV S300
P
psok
I have a Sony DAV S300 DVD and recently bought a SOny KV32FX66 TV. I thought I could hook the sound output from the TV to the DVD player to tap into its surround sound but can't get it to work. Does anyone have any thoughts on how this should be hooked up?
kelvin
Hmmm... this is quite possibly in the wrong forum but still... ;)
You need to connect a standard set of phono's from the audio outputs on the back of the TV, to the "Video 1" (or 2!) inputs on the back of the DAV. When you want sound just select "Video 1" (or 2 ;)) as the function on the DAV and away you go... :)
Hope this helps...
Kelvin.
Lex
Moving to DVD Hardware...
psok - please make sure you post your questions in the appropriate forum as then you are more likely to get the answer you are looking for. ;)
P
psok
Lex : sorry it was on the wrong board. All I can say is that I'm new:(
Thanks to KelvinP I got my problem solved last night. What I'd missed is the the DVD doesn't automatically switch so on the DAVS300 you have to press the helpfully named "function" button on the remote until the sound "appears". The manuals that come with these devices are terrible. Fine if you know what you are doing, but for the rest of us I don't think enough effort goes into them
Anyway, thanks KelvinP
Samsung S95B QD OLED Review - A Quantum Leap for OLED!
