Connecting to PW6
Discussion in 'Plasma TVs Forum' started by mikatt, Sep 25, 2004.
  1. mikatt
    mikatt
    Dec 22, 2003
    176
    Hampshire UK
    +6
    I get my PW6 next week and have a DVD recorder which is RGb, a Humax PVR which is RGB, and a VCR which is composite, I intend daisy chaining the PVR and the DVD through to a JS scart to VGA unit, and the VCR to a Panasonic scart board, would using a scart switch such as the Quintro for the DVD and the PVR be better than daisy chaining.
    Mike
  2. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    It would be cheaper (quintro £60)
    But you can't do Picture in Picture with only 1 input
    Also does your VCR have an RGB output? Unless it does, you will have to either use
    a SCART terminal board or loop it thu the DVD recorder.
