Connecting to mapped drives
Discussion in 'Cables & Switches' started by Steve Bate, May 25, 2004.
  1. Steve Bate
    Steve Bate
    Nov 10, 2002
    680
    Tarporley
    +11
    I've got a HCPC playing ripped DVD's from my AVServer, until this week playing the ripped DVD's by pointing Theatertek to the mapped drive and relevant VIDEO_TS directory worked perfectly. Now TT wont fire up the relevant movie unless I go into explorer and expand the relevant mapped drive\directory, kill it then try again. It's almost as if XP isn't automatically connecting to the mapped drives when it boots up on the HCPC, the AVServer is up 24x7.
    Any ideas?
    Steve
  2. KW1816
    KW1816
    Jun 14, 2002
    836
    Surrey
    +14
    I had a simliar problem and it turned out to be power management on the server.
    The drives were spinning down after 10 mins, explorer would 'wake' the drives fine but the application wouldn't.
    I never got to the bottom of it - just turned off the power management.
    Hope this helps :D
    Kevin.
  3. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    It is most likely the htpc not loading the network card driver early enough. You may need to delay logon.
    XP continues to load drivers after the desktop appears, as a rule of thumb, when you installed XP, if it automatically installed the network card, it loads the network driver higher up the list, if its not loaded before XP trys to map the drives they fail to map.
    I have a work around which involves running a batch file which waits for 10 seconds before mapping the drives, if you want it I'll send it to you and explain what to do.
  4. Steve Bate
    Steve Bate
    Nov 10, 2002
    680
    Tarporley
    +11
    Thanks John, I'll PM you email addy
    Steve
