Connecting to Internet Through BT
Discussion in 'Playstation Forums' started by JJon1, Apr 30, 2007.
  1. JJon1
    JJon1
    I have a PS3 and have been trying to connect it to the net, but have been far from successful! I have a BT Voyager 2000 wireless connection. When setting up the network connections, I don't have a clue what all of the terms and abbrivations mean. I have the WAP security key etc and the PS3 does recognise the Router when I scan. I also have the router's IP address. The connection always fails though and alot of the time, I get the error code:"8013013E". Can any of you help? Provide a guide etc. Thanks.
  2. Darsh
    Darsh
    Feb 23, 2007
    662
    London
    +26
    Mate have you tried setting all the selections to automatic maybe that would work? Basically if you want to do it manually you will have to make sure the information is exactly the same from your PC to your PS3 otherwise the PS3 won't detect the changes made i.e SSID etc. Hope this helps :)
  3. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
