Connecting to a surround amp
Discussion in 'Desktop & Laptop Computers Forum' started by Gilbers, Apr 6, 2005.
  1. Gilbers
    Gilbers
    Nov 17, 2004
    628
    43
    +101
    I'm looking to connect my PC to a surround amp, and I'm wondering if I can use just a digital connection (as I do with my Xbox and PS2) or will I have to connect a set of analogue cables too?
    As I understand it, the DTS/Dolby Digital stream from a DVD will be passed through to the soundcards SPDIF connecter, but can I get all other sound from the PC (games and other applications) to go out via the SPDIF too?
    I have yet to choose a soundcard, so if I need a particular model to achieve this I'd apreciate some recommendations.
  2. mjn
    mjn
    May 24, 2001
    18,392
    Herts, England
    +5,477
    Depends on the soundcard, but you can usually just use the digital out for all your needs.
  3. Gilbers
    Gilbers
    Nov 17, 2004
    628
    43
    +101
  4. inzaman
    inzaman
    Dec 16, 2002
    7,888
    Derby
    +941
    For DVDs then definitely yes the Dolby/DTS soundtrack will go straight to the amp. For games however i am pretty sure that you need this encoding within the PC, from what i understand that is also what that link is saying.
  5. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Normal sampled audio (WAVs) can be output as 2-channel PCM which a receiver should be able to handle .. you should only need an encoder if you want to output in Dolby Digital form for some reason, eg. it's a game with surround sound.
  6. Gilbers
    Gilbers
    Nov 17, 2004
    628
    43
    +101
    Cheers for the advice!
    Looks like I'll have to save my pennies for a Dolby Digital encoding card then.
