Connecting to a panasonic TX36PD30
Discussion in 'General TV Discussions Forum' started by joejag, Oct 29, 2004.
Tags:
  1. joejag
    joejag
    I have a panasonic tx36pd30 tv how do I connect up my panasonic dvd recorder model #DMR-E55 & panasonic vcr model # NV-VHD1 to it plus an ntl cable set top box. I also need to know how they connect to each other, thanks
  2. Tight Git
    Tight Git
    Mar 3, 2004
    6,331
    +597
    Hello Joejag (welcome to the Forum :) )
    There's a diagram in the PD30 Operator Instructions which answers your query.
    If you've lost your manual, post again and I'll dig mine out.
    Unfortunately, it's a lot of typing to describe all the connections. :thumbsdow
    (You see I'm a Lazy Git, as well as a Tight one! :laugh: )
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    need all your model numbers and connectivity options to help more than TG suggested (or should that be LG) panny manuals are available online so shouldnot be an issue...PS Nicet Telly :thumbs:
