Connecting tivo and IPTV box to multiple rooms
Discussion in 'Cable TV & Virgin Media TV' started by willyboy, Jun 22, 2015.
  1. willyboy
    willyboy
    Jun 13, 2015
    3
    Uk
    I have both Virgin Media's Tivo box and separately an IPTV box which sends its output signal via a standard HDMI cable and I am trying to figure out a way of sending the signal from them to at least one other tv in the house (ideally 2).
    I believe this can be done using an HDMI sender/receiver, however i do not want to be restricted to watching the same thing on both tv's. So ideally one tv could be watching Virgin while the other is watching IPTV, however i would like the ability to view and control either box from either room.
    Any thoughts on how this can be done?
  2. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    A number of ways depending on your budget.
    The best way would be a HDMI over Cat5/6 matrix with receivers however that is going to set you back over £1500, though would allow for up to 4 TVS and 4 sources and also include IR control from any TV of the sources.
    More messy, but more cost effective way
    1 x 2x2 way HDMI Matrix & 1 x HDBaseT HDMI Over Cat6 extender
    Though limited to 2 Tvs
    Do you have any cabling in place and do you have a maximum budget for this
  3. willyboy
    willyboy
    Jun 13, 2015
    3
    Uk
    No we do not have any cabling in place, this is a retro fit project. Basically I want to send the signals from the lounge to the bedroom, and a second room if possible (but not essential). I was hoping to make use of powerline adapters to send the signal though the home ring main. In terms of cost I am definitely doing this on a very tight budget and would like to get away with this as cheap as possible.
  4. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    You cant just use standard powerline adapters to transmit HDMI signal.
    You would need something like the HDJuiceBox Lite, this has a transmitter two inputs and a local output which then communicate with a receiver over the ring main and then convert the signal back to HDMI. It also carries the IR signal back to teh source so you can change channel.
    http://store.aclasstechnology.com/hdjuicebox-lite-kit---hdtv-over-power-solution-149-p.asp
    10% off for first 50 orders
    Seb
