Connecting things to a PJ
Discussion in 'Cables & Switches' started by robyoung, Sep 29, 2004.
  1. robyoung
    robyoung
    Nov 9, 2003
    940
    Milton Keynes
    +65
    Just dipping in to the market for my first projector and am looking at getting the Panny AE700. Wondering what i will need in order to connect my SKY+, Panny DVD Player (no component or HDMI) and PS2 to it with out having too many wires to the PJ, and also to be able to switch between the PJ and Plasma very easily.
    So what are my options, ideally i dont want to spend a small fortune, but am willing on spending a little bit extra if the benefits are substantial.
    Rob
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,522
    Somewhere in South Yorkshire
    +5,996
    Do you have a home cinema amplifier with video switching and plenty of inputs?
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    ae700 has scart so that makes life very easy.... Scart and a quinro??? Suggest you run some other cables too HDMI and component minimum there are multi core video cables you can buy and leave un terminated for future use etc
  4. robyoung
    robyoung
    Nov 9, 2003
    940
    Milton Keynes
    +65
    Can you point me in the right direction of the Quinro please. did a search and apparantly its a place in Mexico! :)
    I do have an AMp Sony STR DB 930 i believe. I have tried using the video inputs before but couldnt get it to work for the plasma!
    Rob
  5. robyoung
    robyoung
    Nov 9, 2003
    940
    Milton Keynes
    +65
    ahhh! do you mean this.... Quintro
    If you do should that work no problem. I take it when they say you can switch between you TV and VCR outputs.. i could use that for my Plasma and Projector with the other boxes plugged in to the inputs... yes?
    If so i'll get my order in!
    Rob :)
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    check with av-sales but i should think so
  7. AMc
    AMc
    Nov 20, 2000
    7,145
    Near Norwich
    +3,833
    It's cheaper here
    http://www.tek2.com/beyondhifi/acatalog/B_Tech___BT945_Quintro__Ultimate_Scart_Control.html
    Thanks to this thread
    http://www.avforums.com/forums/showthread.php?t=152236&highlight=Quintro
    I bought one of these to allow me to send my stuff to either the TV or PJ.
    Haven't had the time/inclination to attack the rewiring yet, but it supports 2 RGB outputs from 4 inputs and I couldn't find anything else that did. The model that does this has inputs labled 1-5, the older version doesn't do 2 RGB outputs and has them labelled TV, VCR1, LD etc.
    Beware the SCART sockets are really close together so you may need to buy some straight plug SCART leads
