connecting system
Discussion in 'Cables & Switches' started by grahalex, Jan 27, 2004.
  1. grahalex
    grahalex
    I have a Panasonic tv with 2 scarts, vcr with 2 scarts, dvd player with 1 scart and a sony freeview box with one scart for tv and one to go to video.Can I connect up this system without the need for a scart block?
  2. bobbypunk
    bobbypunk
    not conveniently, but yes you could
  3. grahalex
    grahalex
    Could you give me more detail bobbypunk
  4. Malky1903
    Malky1903
    Jul 2, 2003
    1,908
    48
    Aberdeen
    +64
    DVD straight to AV1 [RGB] on your TV.
    Freeview to VCR in on the VCR and then TV out on the VCR to AV2 on your TV.
    I think that's the only way but I could be wrong.
  5. CARLOS
    CARLOS
    Feb 11, 2001
    5,913
    WEST MIDLANDS
    +1,201
    Would be better to connect freeview direct to Tv and VCR into the other scart on freeview.
    That way you could be watching a freeview channel and record one of the five terrestrial channels at the same time :)
    Also as Malabbey says connect DVD to AV1 as that accepts RGB (make sure you have switched the RGB output on in the DVD menu) and Freeview to AV2 which accepts an S/Video input (set Freeview to output S/Video if it has the option) !
  6. grahalex
    grahalex
    In my TV manual it doesn't say that either of the scart sockets are rgb, its about 5 years old. Anyway I've connected freeview to tv scart 1,dvd to scart 2, vcr to freeview and it all seems to work ok.
