mexicatz
I have an old surround sound system that uses two RCA style connectors. The tv doesn't have these ports. I was wondering what converter I would need to get it hooked up again. My old tv I just plugged them into the back.
You can spend a lot of money on a proper hi-fi DAC but, to be fair, they can also be bought fairly inexpensively from places like Amazon if you're happy to settle for an (essentially) unbranded device made in China.There isn't a headphone jack on the tv. Do you know the type of DAC I would need if I tried that route before buying a new AVR? Figured I could test one out if they were cheap and just return if it doesn't work well.
What brand and model is your TV?There isn't a headphone jack on the tv. Can you recommend a DAC I would need if I tried that route before buying a new AVR? Figured I could test one out if they were cheap and just return if it doesn't work well.
Samsung qn90aWhat brand and model is your TV?
