Connecting stereo speakers to amp
Discussion in 'Hi-Fi Stereo Speakers' started by Westfield, Oct 24, 2005.
  1. Westfield
    Westfield
    Dec 20, 2004
    46
    Kingston Upon Thames
    +196
    I am considering buying a new reciever (Denon AVR-2106) and as a temporary measure, until I can afford a decent set of speakers, I would like to use my existing Sony stereo speakers (SS-H3600) for the front channels (and for stereo music).
    The only problem is that these speakers consist of two units each: One midrange/tweeter unit and one woofer unit. Each unit is independently wired. Is it possible to use these speakers with this receiver?
    I would like to able to use the woofer units if possible as I don't have a sub’ at the moment.
  2. Mentally
    Mentally
    How many wires coming out of each speaker? are there 4 total units?
  3. Westfield
    Westfield
    Dec 20, 2004
    46
    +196
    There are connections for two cables on each unit (2 units making the combined speaker). Therefore a total of 4 cables for both left and right
  4. Roohster
    Roohster
    Jul 1, 2004
    4,782
    Derbyshire
    +5,992
    Can't see why it wouldn'twork as a temporary measure.
    Connect the two positive wires from each speaker to the positives on the amp, same for the negative. In effect you'll be 'bi-wiring'
  5. Westfield
    Westfield
    Dec 20, 2004
    46
    +196
    Thanks for your help, I hoping that I could bi-wire them.
  6. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    do the speakers have impedance rating on them? You may risk damaging something if the impedances are grossly mismatched.
  7. Westfield
    Westfield
    Dec 20, 2004
    46
    +196
    Yes, they are:
    Satellite unit: 8 ohms
    Bass unit: 6 ohms
