Question Connecting sound at to projector.
Discussion in 'Soundbars, Soundplates & Soundbases' started by Jaybey, Jun 16, 2015.
  1. Jaybey
    Jaybey
    Jun 17, 2010
    297
    +6
    hi, I'm not completely sure wether this is the right section to post but I have an issue getting sound to my projector. I inherited a sound bar and projector from a friend and can't connect the audio to it.
    The sound bar has 2 RCA phono ports (red and white) the projector has 4 RCA phono ports (left in/out and right in/out). I presume by getting some kind of splitter that I will be able to connect the leads I have and get the sound. Is this correct?
    I'm a real newbie to this so apologies if there is a simple answer to this.
  2. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    What are you connecting to the projector ?
  3. Jaybey
    Jaybey
    Jun 17, 2010
    297
    +6
    Edit to the first post. They are RCA phono connections. I will be connecting my tv and ps4 to it. The projector has a HDMI port and I can get sound through the built in speaker but as it sits behind me i need to get the sound under the screen.
  4. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    Which projector ?
  5. Jaybey
    Jaybey
    Jun 17, 2010
    297
    +6
    This is the only info I have on it (no box).
    These are the connections on the back.
  6. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    Aha, dont take this the wrong way but a nasty cheap model, the RF tuner gives it away.
    I doubt you can connect via HDMI and get audio via the audio out
    Which soundbar ?
  7. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
  8. Jaybey
    Jaybey
    Jun 17, 2010
    297
    +6
    No offence. This is hopefully just temp until I convince the wife we need a new one.
    forgive me but as I can get sound through the build in speakers of the projector is it not a case of just connecting the RCA cable from the projector to a speaker to relay the sound? So for example:
    If I plug in the RCA cable to the sound bar then split them so they connect into all of the RCA ports in the projector (both left and right) would that not allow the sound to come through the sound bar rather than the projector?
  9. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    how is the ps4 connected to the projector at the moment
  10. Jaybey
    Jaybey
    Jun 17, 2010
    297
    +6
    Via HDMI.
  11. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    Ok then the issue is that the HDMi audio goes to the speakers but not out again.
  12. Jaybey
    Jaybey
    Jun 17, 2010
    297
    +6
    Yea. Do I just need to connect to the left out and right out or to all the ports?
  13. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    No, it just wont do it.
    Get the DAC i linked to
  14. Jaybey
    Jaybey
    Jun 17, 2010
    297
    +6
    Ok, thanks for the help!
  15. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    Sorry for being a bit short with my answer but you are chasing an impossibility
  16. Jaybey
    Jaybey
    Jun 17, 2010
    297
    +6
    It fells that way. Im looking at the DAC now, it looks like the 'end' connection is a coaxial port. Where would this connect to on the projector?
  17. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    PS4 - HDMI Cable - Projector
    PS4 - Optical Cable - DAC - Dual RCA (red and white) - Soundbar
  18. Jaybey
    Jaybey
    Jun 17, 2010
    297
    +6
    Brilliant. Cheers!
