connecting skyHD to amp
Discussion in 'Sky Digital TV Forum' started by clayf1ghter, Jan 24, 2008.
  1. clayf1ghter
    clayf1ghter
    Jan 24, 2008
    11
    wonder if anyone can help me with this...........just purchased skyHD all up and running looks sweet but when I bought it I didn't check my amplifier to see if there was an optical port for it to connect to so I could take full advantage of the dolby surround. Unfortunately there is'nt there is only one for cd and one for dvd. So I've got the dvd set up as normal but now I've got the skyHD running through the optical cd port. It sounds fine but cant help but wonder whether I'm damaging my amp by doing this or whether the sound would be even better if it did have an optical port for the tv.
    I'm into my my av kit but when it gets a bit more tecnical I'm lost, any advice would be greatly welcome.
  2. Rich Marshall
    Rich Marshall
    Nov 14, 2006
    3,717
    Kirkby In Ashfield
    +585
    All optical is the same as I understand it, it's only light anyway so I don't see how it can damage your amp.
    Are you using a 5.1 surround amp?
  3. .Griff.
    .Griff.
    Feb 1, 2004
    992
    Shropshire
    +84
    I'm a bit confused mate.. Initially you say your amp hasn't got any optical inputs yet you then go onto to say "I've got the skyHD running through the optical cd port".
    If you meant there's no auxiliary optical input and your using the CD optical input instead then I can't see the harm in that.
  4. clayf1ghter
    clayf1ghter
    Jan 24, 2008
    11
    There is optical for the cd and for the dvd but not for tv sorry if wording confused ...long day. You dont think the sound would be any worse by not using a dedicated input?
  5. clayf1ghter
    clayf1ghter
    Jan 24, 2008
    11
    Yeah its 5.1, it sounds good enough to me just wanted to make sure wasnt doing any damage and was getting the most out of the equipment.
