connecting sky to projector and tv.
Discussion in 'Cables & Switches' started by Sandman, Oct 17, 2003.
  1. Sandman
    Sandman
    Nov 28, 2002
    3,607
    Glasgow
    +1,339
    Having just got me panasonic pt-ea100 and watching a couple of dvd's on it I am very happy. However I then went to connect my pace sky digibox to it and found the only way I could do this was by unplugging the scart cable that goes to my tv and changing it for a scart-phono cable which then goes into my projector.
    Is there any way I can connect the sky digibox to bot my tv and projector at the same time? The other scart on my digibox goes to my vcr.
  2. Mirablo
    Mirablo
    Jan 16, 2003
    70
    can you not daisy chain the sky through the VCR to the PJ?
    sky------scart-scart-----vcr----scart-phono---------PJ
  3. Sandman
    Sandman
    Nov 28, 2002
    3,607
    Glasgow
    +1,339
    No, it is an old cheapo VCR that only has one scart socket so this isnt an option.
    I was thinking there might me a lead available that at one side has a normal scart socket and at the other side has a scart socket and a video phone plug.
    Any other ideas?
  4. Mirablo
    Mirablo
    Jan 16, 2003
    70
    you can get a scart splitter tho im dubious as to the signal quality
  5. timlloyd
    timlloyd
    Jan 15, 2003
    278
    Warwick
    +9
    B-tech do a range of products which should help and the following seems like what your after
    http://www.b-tech-int.com/BT929-S.html
    This site sells them, I've used them previously and service is quite good. Cables are good value if you need them also.
    http://www.beyondhifi.net/
    You may also want to take a look at sky+ now the sub has been dropped, you get svideo out aswell as RGB scart, makes a big difference on a PJ compared to composite and you also get optical out for DD etc.
  6. owenw
    owenw
    Jul 19, 2003
    269
    Ireland
    Can your TV output an signal from one of the SCART sockets if you have any spare?
    Sky -> TV -- TV -> PJ The composite picture quality won't be fantastic though. As Tim said, you might want to look at getting Sky+ for S-Video
  7. Sandman
    Sandman
    Nov 28, 2002
    3,607
    Glasgow
    +1,339
    Thanks Tim, looks like excatly what I am looking for. Owen, for this to work would the tv have to be switched on?
  8. owenw
    owenw
    Jul 19, 2003
    269
    Ireland
    Mmm good point. Sorry I don't know. At a guess I'd say you would need it on, which isn't too helpful when you're using the PJ
