Connecting Sky to Bedroom - Help
Discussion in 'Sky Digital TV Forum' started by Gliese 581c, May 25, 2005.
  1. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    7,831
    On AVForums
    +522
    I have just finished running a coax cable under my floor, up the wall and through the ceiling to my bedroom to watch sky on my lcd in there.
    Prob I have is that the coax wont run audio, will it ? It will only carry picture ? - If so, anyway around this, or will I have to feed audio cables through also ?
    One final question, what connectors am I looking for to connect to the coax cable ends ? I think they are called 'F' connectors ? Not sure what to pick up but I'll be connecting it to my 2nd out on Receiver into Ariel socket on the tv.
  2. johndon
    johndon
    Feb 3, 2002
    1,930
    48
    +89
    Not sure about the connectors but the coax will feed audio.
    John
  3. JayCee
    JayCee
    Jan 20, 2004
    20,227
    Lanarkshire
    +1,937
    Yes it will, this is called an RF connection.
    They're called "Coaxial connectors" (or coax as they're generally known).
    You will need a female connector at the Satellite end (or a coax plug and coax coupler) and a coax plug at the Tv end.
    Tune your Tv to channel 68 (the default chan Sky digiboxes are set to).
    An "F" connector is the type of plug fitted to the dish downlead.
  4. av2diefor
    av2diefor
    Read this http://www.satcure.co.uk/digifaq2.htm#menus
    This should help you understand what goes on in rf out of the digibox.
    This will allow you to fine tune it, sometimes it's better to change the rf output to a channel at least +5/-5 away from existing rf signals .
    Check the site out, all the answers to all the questions! :lesson:
  5. derbyjj
    derbyjj
    Feb 16, 2005
    238
    Rainhill
    +19
    It will be mono sound and you can get the connectors at wilkinson B&Q etc
  6. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    7,831
    On AVForums
    +522
    thanks guys :)
