Connecting Sky, Sony DAV-S300 and Sharp LC26GA4E
Discussion in 'Cables & Switches' started by Blakey, Aug 16, 2005.
  1. Blakey
    Blakey
    I have a Sony DAV-S300 DVD, a Sharp LC26GA4E LCD TV and Standard Sky (not Sky+). At the moment these are connected as follows:
    Sky -> TV
    DVD -> Surround Sound speakers
    DVD -> TV
    1. This means that I can watch Sky on my TV but the sound comes from the TV, not the surround sound speakers on my walls.
    2. Also, I can watch a DVD and hear the sound all around the room, and the picture comes from the TV.
    What I would like though, is to get the Sky sounds piped into the DVD system, so that I can listen to the TV with the sounds coming out of the DVD speakers, not out of the TV. That way I can remove the speakers from the sides of the TV and reduce its size. It would also mean I could put the radio on Sky and listen to it without having to have the TV on.
    Can someone please explain in simple terms what leads/connections/cables I should be using to get the most out of this setup?
    I'm a total nonce when it comes to audio stuff, so please excuse my ignorance!
    Thanks heaps
    Blakey
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    A pair of phono leads from the Sky box into the Sony Dav should do it.
  3. Blakey
    Blakey
    Thanks for the swift reply. Sorry, excuse my ignorance, but are we talking 2 connectors at each end? I have an audio connection which has a 3.5mm jack at one end and a double audio (red and black) connection at the other end. I use that to plug my ipod into the DVD to listen to it. Can I use the same cable, or do I need a red/black to red/black cable?
    As you can see I really am clueless!! :)
    Blakey
  4. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    I'm afraid that I am equally clueless about ipods. I would guess that what you are describing has a pair of phono cables at the end that plugs into the DAV and what you need is a pair of cables with those connectors on either end.
  5. Blakey
    Blakey
    Sorted! Thanks for the help - I went home and rummaged in my cables draw and found an old audio cable - with a left and right audio channel on each end. One plugged into the Sky box, the other into Audio In on the DVD and bingo! I now have Sky coming out through the DVD and can remove the speakers on the TV if I want to.
    Thanks for your help!
    Blakey
