METALMICKY
Hi folks.
Can anyone please advise on this connection issue?
Just purchased a new LG 4k smart TV for the lounge which is connected to a Sky HD box. Sky Q is on order but for obvious and totally understandable reasons it won't be arriving any time soon.
However, in the interim the old 32in Philips 32PF5320/10 HD ready TV is being moved to the bedroom ( Visit the support page for your Philips Flat TV 32PF5320/10). I have the sky multi room HD mini box in the bedroom currently connected to a small LG LCD TV that may have HDMI connection but has an awful viewing angle. Hence the plan was to replace this with the Philips TV which has a pretty impressive picture.
However, the key issue with the Phillips is that is does not have any HDMI connection but rather it is DVI. When previously connected to the Sky HD in the lounge this was not an issue as I used and HDMI to DVI lead for the video and to get the audio I used the DVI audio in connection into the Sky box's audio L & R (red and yellow) . This worked fine.
Of course on inspection of the mini multi room box there are way fewer connections with potentially the only one being labelled ' Digi In ' which looks a lot like an optical input and is hidden under a little plastic flap. The HDMI to DVI adaptor lead works fine into the single HDMI connection on the sky box for the video. Is there any sort of cable or device that will allow me to get the audio to work?
Whilst scratching my head I've got round the issue by simply connecting the TV to the sky box by scart to scart. Of course this rather defeats the object as whilst I have video and audio the picture is not HD and pretty rubbish.
Would be very grateful for any advice. Really hope there is a simple solution as loathe to bin off the Philips which has a pretty good picture and has lasted 12 years! I guess my next question is if I eventually upgrade to Sky Q multi room will I again have problems connecting the Sky Q mini box to the old Philips add what would be the solution to that scenario.
Many thanks
Many thanks
