Connecting Sky Digital to your Plasma? - Solution at hand
S
sbelo
Just bought the new Hitachi 42" 42PMA400E Panel
Fantastic- Out performs both the Tosh & Pana products.
Also bought a special cable from Nexnix.co.uk (01403) 756777
I can now display RGB (via Scart) from both Sky Digial & DVD along with viewing the Video on Composite input from the same cable. As well as still being able to video from Sky etc
This cable gives a superb picture on sky as well as other sources.
And also because it's RGB it out performs both S-VHS & Composite.
Cable cost me £60 + vat & sorted out all of my connectivity problems
Hope this helps
J
JimmyMc
Sounds interesting..
I'm looking at the hitatchi myself.. hopefully you can give me some pointers on it!
Can you use both RGB1 and RGB2 at the same time?
Also.. am I right in saying, like most other plasmas, you can only have composite OR S-Video plugged in?
I'm guessing my connections will go something like this..
DVD via Component
NTL Cable to RGB1 using a JS Tech RGB - VGA converter
PC to RGB2 via ordinary VGA cable
VCR to Composite
I've a Dreamcast that I hardly use but I guess I could just unplug the NTL and swap it over..
Is there some kind of 'stretch' mode to re-size 4:3 images? (a bit like the Panny Just mode - it streches certain parts of the screen more than others..)
Hope you don't mind all the questions!!!
PS - How much did you pay for yours? My local store has them at £3995 plus £230 for the stand..
Cheers, JimmyMc
Dutch
Hi Jimmy,
Just to let you know that www.ivojo.co.uk have the Hitachi for a reasonable £3222, which doesn't include a stand. Quite a saving on your other price though :)
Steve
DaveCheltenham
Originally posted by sbelo
....... I can now display RGB (via Scart) from both Sky Digial & DVD along with viewing the Video on Composite input from the same cable. As well as still being able to video from Sky etc
Cable cost me £60 + vat & sorted out all of my connectivity problems .......
Or if you want to make up your own cable, the connections are Composite Out: 19/17 (E), Red: 15/13 (E), Green: 11/9 (E) and Blue: 7/5(E). The second number on each is the earth screen. Be sure on the Plasma RGB input menu to select the correct sync source; AV.
J
JimmyMc
If I were to take apart a JS Tech (or similar) RGB-to-VGA box, is this what I'd find?
I might have a go at making my own if that's the case! (and probably end up buying one anyway.. my soldering skills aren't what they used to be!)
MarkTaylor
Absolutely not :)
There is a lot more to one of the JS boxes than a little cable rearrangement.
You just can't get the quality of sync signal with only a little re-soldering, but it is works for you then good luck, but it will not work with all sources and displays.
Mark
DaveCheltenham
Originally posted by MarkTaylor
Absolutely not :)
Mark
Mark - I am not into knocking anyone's equipment. sbelo and myself use a direct RGB input to the Plasma connection board specifically designed for it; this is combined with the sync input to the AV input which is designed to take the composite sync input. I have the Panasonic BNC input board on a PW425B.
If it is convenient to use this arrangement, full attainable RGB quality is achieved as long as reasonable quality cables are used. Arguments put forward for using the Syncmaster or JS units include improved flexibility for different inputs. i.e. Having Component as well as RGB as the Syncmaster or JS units can use the VGA input which requires separate Horizontal and Vertical Syncs. My point in making a posting in the first place was to be of assistance to people who do not need additional units for RGB quality or do not want to spend a lot on a bought in cable.
Hope this clears up any misunderstanding.
MarkTaylor
NP, I was reacting to JimmyMc's comment, not your original post :)
Mark
J
JimmyMc
Yep - I have been sold on the JS Tech front.. I'll be ordering one soon.. before I get my plasma..
I went and had a nice hours worth of viewing the hitachi earlier today.. We first used a Cyrus (spelt? - sorry.. just got back from the pub so spelling's probably not quite right! ) DVD player and there were some really visible diagonal banding going on.. we wondered if it was due to a lack of progressive scan or something so we swapped to an Arcam.. which cured the fault.. although it also cured it with prog scan turned off.. a bit of a worry if I'll need over a grands worth of DVD player to get a decent pic!!
What I saw though made me very very tempted indeed with the Hitachi but I'm going to hold out until I manage to persuade someone to get a Pio MXE out of stock and demo it.. :) )
A
att
This Hitachi 42" 42PMA400E sounds like an interesting model (even though the fan noise may be disappointing) but can somebody confirm the type of connections it has. The brochure that can be found from http://www.hitachidigitalmedia.com/ lists two analog RGB computer inputs (15 pin mini D-sub and 5*BNC), but also says that the horizontal frequency range is 24-106 kHz, which to me sounds like these connections do not accept PAL/NTSC-based RGB signals, not even when using one of those famous rgb2vga-boxes.
The connections listed include also one component video input (format: Y, PB, PR or Y, CB, CR). Elsewhere in the brochure they say that "a component video input caters for DVD and HDTV" and "RGB video input allows the plasma to accept RGB signal from DVD players and/or terrestrial boxes". So, what is this RGB video input, is it the same as the component video input or a separate one? In other words, can you connect simultaneously a DVD player with component output and e.g. a digi-tv-box with RGB output to 42PMA400E?
Antti
symanski
Broadcast quality sync extractor which gives you true H & V syncs, supported by a little computer running a program written by myself.
There's quite a bit of technology put in to the design of the unit. It's very advanced, going through several prototypes to get to this current design. Any other solution would simply be a step back.
All the best,
Dr John Sim.
symanski
Antti
For the RGB to Plasma VGA unit to work, you do need a screen which can display from 15kHz. The most popular screens seem to be those from Panasonic and Pioneer, which are both have compatible models. Some of the newer screens from other manufacturers new to plasma screens seem to have decided not to start at 15kHz (bit of an oversight).
However, all is not lost! You can still go for RGB to Component conversion to get an excellent picture.
All the best,
Dr John Sim.
S
sbelo
As I understand it from my Plasma.
Hitachi are working on a fix for the fan noise, I will update you when I have the fix.
The beauty of this panel is what signals you can put in to the panel.
For instance:-
My DVD is connected via Component out, to either of the 15 Pin VGA input on the Plasma using an old style VGA to 5xBNC Monior cable in reverse with 3 BNC to Male Phono converters to fit the DVD.
My Digibox is connected via Scart to the component & composite input on the plasma running RGB from the Sky box.
The Hitachi Plasma then turns the component input in to RGB using the composite in phono as the sync for the signal instead of it being included in the green channel as in component.
This will then let you watch sky on either rgb or composite by the special cable I got from Nexnix.co.uk
I then scarted my video to the sky box & can watch it via the same connection over composite. All I have to do is press the video 1 button on the remote & the source switches.
I do not use the S-video input as it takes priority from the composite input.
This leaves me a spare 15pin VGA port which I hook up to my PC & boy does it perform well.
With this configuration I am able to use the Pic in Pic mode, Actually its a split screen. I can watch a DVD or have the PC on half the screen & Sky or Video VCR on the other side. Very usefull when working from home
All of the above connections work very well & give excellent pictures. Having looked in the high street shops since buying this panel, I am convinced that I have as yet not seen a better performing panel/picture quality.
I bought all my kit through Nexnix.co.uk as they have an in house demo suite & I was able to compare the Hitachi against both the Tosh & Pana products I also believe that I could not have had better service or pricing from them. :cool:
J
JimmyMc
Hi sbelo..
Would you mind letting me know which DVD player you are using? i take it you're not seeing the diagonal banding I saw when i went for a dem!
Cheers, James
A
att
Thanks, that will be important information.
Does your DVD output progressive scan? If not, the horizontal frequency would be only about 15 kHz, i.e. outside the specs given by Hitachi whereas with prog scan you would get about 30kHz (correct?), which would explain why this works. Do you use both PAL/NTSC prog scan?
The Hitachi Plasma then turns the component input in to RGB using the composite in phono as the sync for the signal instead of it being included in the green channel as in component. This will then let you watch sky on either rgb or composite by the special cable I got from Nexnix.co.uk I then scarted my video to the sky box & can watch it via the same connection over composite. All I have to do is press the video 1 button on the remote & the source switches.
OK, sounds good. Thanks for the info.
Antti
S
sbelo
Hi JimmyMc
I use a Sony DVP-S7700
I do not get any banding at all. Where did you go for a demo?
Against the Pio The hitachi was better particularly on Reds. Ok I aggree that the the Hitachi was noisier, but this is being addressed acording to Hitachi.
If you want to see the Pio or the Tosh (same panel) v the Hitachi mail [email protected] (He's the MD) I think he has all 3 units set up in his demo suite. He will also be able to advise you on the DVD & will probabally use the top of the range Denon to show you
Hope this helps
Steve
SBELO
S
sbelo
Hi Antti
Re the DVD Output
I'm using the Sony DVP-S7700 which is not a Prog scan DVD (about 3 years old, but still very good)
As I understand it the Hitachi Panel has a number of multiple use inputs. As you know I am using the Pc inputs to show DVD. There is an option to switch the type of input in the Plasma menu from RGB to Component under both VGA inputs. You are correct I am outputting 15.5KHz and it does not work under the RGB setting. But change it to the Component setting & it works as sweet as a nut.
Hope this helps
Steve
SBELO
LG CX 4K OLED TV Review: The best TV of 2020?
Trending threads
