Connecting Sky+ Box to Projector
Discussion in 'Sky Digital TV Forum' started by NightFox, Feb 23, 2005.
  1. NightFox
    NightFox
    Feb 22, 2005
    65
    Whitchurch, Shropshire
    I’ve currently got my Sky+ box connected to my TV via SCART, and I’ve just brought a LCD projector (Panasonic AE700). What I want to do now is wire up the PJ to the Sky+ box, but still have the TV connected to it. Are the two SCART outputs on the Sky+ box always live, or will only one work at a time? If only one at a time, what are my options? (I can’t remember what other outputs are on the back of the Sky+ box)
    I’m pretty new to this stuff, so I could also do with some advice on connections – the run from the Sky+ box to the PJ is going to be about 10m – am I right in thinking that the best way to do this is going to be a 10m SCART -> RGB cable? Or would just a 10m SCART -> SCART be best? Seems a bit daft to be carrying the audio to the PJ as well though…
    Any help, much appreciated!
    :lease:
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    best bet in your situation is probaly run S-video from SKY+ box to PJ
    keep both displays connected and viewing same channel...... what else do you have? DVD player AV AMP etc? there may be a better way available if you spend a few quid....
  3. NightFox
    NightFox
    Feb 22, 2005
    65
    Thanks for the quick response.
    When you say S-Video, does the Sky+ box have a "normal" S-Video output as well as the 2 SCARTS, or do I have to use one of the SCARTs with a SCART-> S-Video lead (sorry if I'm talking rubbish, but my grasp on this is somewhat weak!)
    My full set up will be:
    Sky+ -> TV (SCART)
    Sky+ -> PJ (???)
    DVD -> TV (SCART)
    DVD -> PJ (HDMI)
    The PJ inputs are:
    S-VIDEO IN: Single-line, Mini DIN 4-pin
    Y: 1.0 V [p-p], C: 0.286 V [p-p], 75 Ω
    VIDEO IN: Single-line, RCA pin jack
    1.0 V [p-p], 75 Ω
    PC IN:
    RGB: Single-line, D-sub HD 15-pin (female)
    R.G.B.: 0.7 V [p-p], 75 Ω
    G.SYNC: 1.0 V [p-p], 75 Ω
    HD/SYNC: TTL high impedance, automatic positive/negative polarity compatible
    VD: TTL high impedance, automatic positive/negative polarity compatible
    COMPONENT IN:
    Y, PB/CB, PR/CR Single-line, RCA pin jack x 3
    Y: 1.0 V [p-p] (Including sync), 75 Ω
    PB,PR (CB,CR): 0.7 V [p-p], 75 Ω
    HDMI IN: Single-line, 19-pin HDMI connector
    ...assuming that makes more sense to you than it does to me!
    Thanks again
    Neil
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    yes Sky+ boxes have a dedicated 4 pin Mini DIN S-video socket on the rear so just need a decent S-video to S-video cable
  5. NightFox
    NightFox
    Feb 22, 2005
    65
    Thanks, I'll go for that then, though (at the risk of being hopelessly wrong) would this also be an option to go from the Sky+ SCART to the PC input on the back of the PJ:
    SCART -> 15 Pin HD Male RGB (Wired RGsB)
  6. NightFox
    NightFox
    Feb 22, 2005
    65
    ...and I guess should have added both are connected to Sony STR-DB930 amp
  7. Starkiller
    Starkiller
    Nov 3, 2003
    202
    +3
    Keane do a RGB scart to 15 Pin RGB kit
    i use for my themescene it was about 100 with 10m lead(option extra, need to call them about this)
    works ace for Sky and DVD
