Connecting Sky+ box to a VCR
Discussion in 'Sky Digital TV Forum' started by ftogpx, Oct 30, 2004.
  1. ftogpx
    ftogpx
    Hi guys, i'm trying to connect my pace sky+ box to my sony vcr so I can record some saved programmes to video. I've tried connecting with a scart cable, but all I get is a picture, no sound. TV is a 21" sony (KV-21CT1).
    I have a normal panasonic sky box connected to the same video downstairs on a sony 29" tv and it works fine.
    Any ideas?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Check the scart cable is firmly seated, slightly crooked can mean the pins carrying audio are not connecting. Make sure you have selected the correct AV input on the VCR as well, also test both scart sockets on the SKY+.
  3. jimcarney
    jimcarney
    Feb 19, 2001
    641
    DOWNPATRICK CO DOWN
    +3
    Make sure the scart is not just RGB!
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    yes you will need to use a FULLY wired scart cable while we are on th subject why not buy a DVD recorder??? PAnny E55 is under £200 now...........
  5. ipd56
    ipd56
    Oct 21, 2004
    88
    11
    peterborough
    +18
    if you press the tv/vcr button on your vcr you will still not here the sound but it will be recorded or connect the sky+ vcr scart to L2 or L3 scart on the vcr and vcr L1 to 2nd scart on tv and will then work like on the panasonic box hope this helps this is because pace configure thescart on the pace sky+ v2 different this make sony and grundig vcr not work the same.
    ipd56
