connecting sky+ and prog dvd
Discussion in 'Cables & Switches' started by satch, Jan 3, 2004.
  1. satch
    satch
    hi ,
    im looking at purchasing a prog scan dvd to connect to my panasonic 5 plasma.
    the problem is i have my sky+ connected via a qed squart scart to 6 phonos into the component input on the tv so it outputs a rgb signal.
    so what i need to know is what cables or options would i require so that i can have my dvd running progressive scan and the sky+ still giving a rgb signal?
    thanks,
    paul
    :cool:
