Connecting set-top box to Sanyo Z3 using VGA adapter
Discussion in 'Projectors, Screens & Video Processors' started by dancingmatt, Aug 3, 2005.
  1. dancingmatt
    dancingmatt
    Apr 26, 2005
    433
    +13
    Hi all
    If I connect my set-top DVD or Freeview box to the VGA input on the Sanyo Z3 via an adaptor (such as Sanyo's own one) I know I have to set the "Computer" input to RGB(Scart). But I won't be able to use the colour or tint image settings via this input, although I gather I will still be able to change rgb white balance, rgb gain, rgb offset and rgb gamma.
    Is this a problem? Will I have difficulty getting a good PAL DVD or Freeview image without being able to change the colour or tint settings and so should use a Scart-YUV converter instead? Or doesn't it matter since all the advanced menu colour tweaks are still available?
    Would appreciate your direct experiences using a Sanyo RGB Scart-VGA adapter, or a different brand for that matter, and whether I'm going to have a problem here...
    Of course, would also love to know a cheap place to get the adapter from! :D
    DM
  2. Liam @ Prog AV
    Liam @ Prog AV
    Well-known Member AVForums Sponsor
    Oct 18, 2002
    8,498
    Kent
    +827
    If you want cheap then get a Keene Syncblaster for Sanyo Z3s - which is basically a straight scart to VGA cable, no sync extraction required!
    If you want decent quality get someone like Van Damme to make you up one using decent video cores!!
    Regarding quality I don't know. Panny plasmas have had this inability to adjust colour but as you say, the advanced menu gives you what you need. TINT adjustment is irrelevant as it's only for NTSC.
