Connecting Reciever to digital out
Discussion in 'Cables & Switches' started by norbi99, Dec 8, 2003.
  1. norbi99
    norbi99
    Hello
    I am trying to connect my home theatre system reciever to the digital output on my soundcard, but so far I could not get the multichannel to get trough.
    Here are my specs:
    Sound card: sound blaster audigy2
    Reciever: Sony STRDE895S
    I use a mono to RCA plug from the digital output of the soundcard, and connect the RCA cable to the coax digital in on the reciever. I configure the soundcard to send the signal without decoding it.
    But still I gen only 2 channels out.
    Anyone was any ideas, or experience with this?
    thanks
    N.
  2. Kramer
    Kramer
    Hi & welcome.
    Have you enabled SPDIF passthrough in your chosen DVD player software?
    Config/audio/spdif.
  3. norbi99
    norbi99
    I am not sure if I can do that in the player.
    But I want to pass all sounds to the reciever, and test the channels... So far I could not do it with sb Audigy2.
    I have an Asus nforce2 mother board with integrated sound, and I was able to connect and get digital multichanel sound to my reciever in notime... Go figure. ..
    Anyone know if this is possible with the sb audigy2 sound card?
    Also, I am looking for a good avi or sound file that is clearly testing all channels, consecutively? WHen I do the speaker test everything sonuds good, but I have a feeling that when I play an AVI with dolby digital sound ( I downloaded those dolby digital intros you can see in the movies before the show starts), the sound is just stereo that comes out of 5 speakers.. This is what I want to find out.
    thanks.
    N
  4. LittleRobotMan
    LittleRobotMan
    Which OS are you using?
    I say this as I am using XP sp2 and keep having to set my speaker selection to 5.1 to get surround to work. I don't know why XP forgets what I set it to, or why the speaker setup should make a difference with SPDIF ...but it does.
    Have a fiddle with your Audio Control panel if you are using XP
