Hi Guys,
I'm really stuck here as i have never used the screw in type speaker terminals. My problem is that when i put the speaker cable into the front hole of the terminal, and then screw until tight, it doesn't actually tighten and i can easily pull the cable straight out. The only other option is to put the speaker cable in the gap between the back panel and the back of the terminal but that seems to difficult to be true.
Do i need spade connectors or banana plugs?
Can anyone please help a newbie out
