Connecting PW6
Discussion in 'Plasma TVs Forum' started by Slynx, Nov 9, 2004.
  1. Slynx
    Slynx
    Nov 6, 2004
    186
    Adelaide. Australia.
    +4
    Yet another hook up query.
    Am planning on purchasing a PW6 and wall mount bracket from AV Sales, but need help on the following. The gear I have at present consists of the following:
    Panasonic TU-DSB31 Sky digibox (2 scarts)
    Sony DAV-S300 Compact AV System (no scarts)
    Sony SLV-SE820 VCR (2 scarts)
    Can anybody help with all the interconnects and whatever else is required? (i.e. add on connector modules etc.) Don't need terrestial tuner as reception is pathetic in our area
    Will probably change or add a DVD recorder at a later stage.
    Thanks for that
    Slynx
