Connecting PW6, Home Cin and PS2
Discussion in 'Cables & Switches' started by Bobby_Dazzler, Aug 14, 2004.
  1. Bobby_Dazzler
    Bobby_Dazzler
    Hi all
    could someone give me some advice on connecting the following in the best possible way.
    Panny Pw6 Plasma
    Sky + box Pace with RS232, Optical , S Video, Scart, Phono Audio Out
    Sony Dav SA30
    with 2 phono Ins ie 2 x red blk and yellow
    1 Phono out ie 1 x red blk and yellow
    Scart
    optical (it says optical on the back but i cant see any socket!!!!)
    PS2 not sure what my options are here!
    Regards
    Bobby :lease:
  2. SamirP
    SamirP
    Apr 28, 2003
    1,303
    South Of The River
    +38
    Hi bobby
    what input boards do you have on your plasma?
    here's one option,
    get a jstech rgb scart to vga converter and use this to connect your Dav to your plasma.
    Sky + via s-video to plasma
    Sky+(Audio) via phono to Dav
    Or you could get a rgb scart switch box and connect the Dav, Sky & Ps2 via rgb scart to the switch box then rgb scart to vga.
  3. Bobby_Dazzler
    Bobby_Dazzler
    I dont have any input boards as yet so i will need to know what to get ... i want to get the plasma and all the additional bits together.
    regards
    bobby
  4. SamirP
    SamirP
    Apr 28, 2003
    1,303
    South Of The River
    +38
    well you could get the component, svhs board + scart board
    Sky via s-video to panny
    Dav via Jstech rgb to vga converter to panny
    PS2 via rgb scart to Panny
    or use a JS Tech rgb to component converter for sky aswell and use the s-video input for your PS2
  5. Bobby_Dazzler
    Bobby_Dazzler
    is it possible to only run one cable to the panny apart from power obviously?
    ie run all on s-video or scart?
  6. SamirP
    SamirP
    Apr 28, 2003
    1,303
    South Of The River
    +38
    You could connect everything via rgb scart to a switch box then have just one scart running to the TV
  7. Bobby_Dazzler
    Bobby_Dazzler
    i think the ps2 will have to be connected via the dav as i will not be getting the pw6 speakers therefore get no sound on the ps2. what about if i run all to scart box then convert that to an s-video to go to the plasma?
