connecting psp to encrepted wireless network
Discussion in 'Playstation Forums' started by wallzy, Aug 2, 2006.
  1. wallzy
    wallzy
    Jan 26, 2005
    562
    +16
    havin a few problems connecting my psp to my wireless network ive got every think entered correct (i think) but when i try to connect it connects to the access point and then it comes up exchanging key information after a min or 2 i get a error message, the key information exchanged timed out. can some help me solve this please
    oh if it helps im trying to connect to a philips wireless router
    thanks
    wallzy
  2. s1hastie
    s1hastie
    Apr 10, 2005
    2,505
    68
    +39
    I had a similair problem to this, with mine, resolved it by going on to the settings on my pc and changing the router to work on both g & b. Can't remember exactly how to do it someone here told me.
  3. shay0
    shay0
    Jan 9, 2005
    5,004
    God's Own County
    +489
    I had the same problem at home/work and the issue lay with the encryption level and the firmware on your PSP. One location was using WPA-PSK and the other 64bit WEP and I couldn't connect with either. Once I upgraded my firmware from 2.01 to 2.71, it worked first time on both routers.
  4. wallzy
    wallzy
    Jan 26, 2005
    562
    +16
    thanks to both of you for your replys any idea how i can update my firmware with out connecting to the internet on my psp thanks
  5. shay0
    shay0
    Jan 9, 2005
    5,004
    God's Own County
    +489
    Well, I tried downloading the firmware update from numerous places on the web and it was corrupt each time. I even borrowed a mate's PSP & memory card to check my card and download the file to his card/PSP, without any luck.
    In the end, I had to do the unthinkable and turn off encryption on my router until the file had downloaded via wireless :eek: Desperate times = desperate measures, but it works peachy now, no matter what the encryption level! This has since been tested on 3 different routers, all using different levels of encryption and worked each time :D
  6. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    Not sure why turning the encryption off was such a problem. While an un secured network is highly undesireable, for the 20 minutes it would have taken to do this the risks were negligable IMO.
  7. wallzy
    wallzy
    Jan 26, 2005
    562
    +16
    managaed to update my psp by connecting it to my laptop via usb i now have 2.80 firmware still cannot connect to the internet thow,im trying to connect threw a wep encripted network when i go threw all th details i click on test connection some times it comes up with the error above other times the psp freezes and restarts
    wallzy
  8. branny
    branny
    Feb 26, 2005
    3,693
    103
    Pie Land
    +275
    I have 2.71 and wireless router. Using WEP then no chance. Using WPA or indeed no encryption then all fine and dandy. Searched internet at time and WEP prob is common.
    Branny
  9. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    I have an old netgear ethernet to wifi adaptor that only does WEP and it never has an issue. Is it a particular make/model of wifi router you guys have problems with?
  10. wallzy
    wallzy
    Jan 26, 2005
    562
    +16
    mine is a philips snb6500
  11. shay0
    shay0
    Jan 9, 2005
    5,004
    God's Own County
    +489
    After spending the last 6 years working in IT Security, paranoid isn't the word when it comes to unsecured broadband :(
    As for the routers, personally, I used a D-Link broadband router, a Netgear ADSL router (can't remember exactly which model) and a Cisco Wireless Access Point.
  12. wallzy
    wallzy
    Jan 26, 2005
    562
    +16
    been trying to sort this out again today with no luck every time i try to test the connection now the psp freezes and shuts down :lease: this is drivin me mad
