Connecting ps3 via dvi
Discussion in 'LCD & LED LCD TVs Forum' started by HK88, Sep 20, 2007.
Tags:
  1. HK88
    HK88
    Sep 20, 2007
    5
    I have connected my ps3 to my pc monitor via DVI-D and audio through the composite cables(red and white)
    Everything works fine. I can play games with sound and hd resolutions. But sometimes when i try to play download games. Instead of having 720p writing on the screen( it shows resolution in top corner for 5 secs) it writes 1280 x 720. Well i couldnt care what it writes but the problem is, sound doesnt work??? So i exit the game and go to the display settings and re-do the cable options then it works again. It has happen 4 times 2day. So i brought a 2x rca to 3.5mm jack to use instead. But now that only works when the other way doesnt. Any help plz
